Can I use my highcap that is now used with my CD 5 to also work with a headliner headphone amp?
Posted by: Jaybar on 16 January 2001
I am considering the purchase of a headliner headphone amp and would not like to buy another power supply if I can help it. I will be using the headliner with a Spectral pre-amp. Thanks.
Jay
Posted on: 16 January 2001 by Mike Hanson
The Hi-Cap can power the CD5 or the Headline, but not both. Catch you later!
-=> Mike Hanson <=-
The Headline needs an audio signal (which would generally come from the tape loop on your pre-amp), as well as a power source (from a NAPSC or Hi-Cap). The four-pin output on the Hi-cap could provide the audio signal as an alternative to the tape loop on the pre-amp (with a special connector, of course), but this socket doesn't provide any power. Catch you later!
-=> Mike Hanson <=-
