Bycicle:campagnolo vs shimano.which one and why?
Posted by: o.j. on 15 October 2004
hy there!today i saw a roadbycicle.it fit s like a glove.perfect size, perfect optic,perfect prize.its gear shifting system i s campagnolo. I know that competitors have shimano.i never had before a race bike with that kind of gear shifting.Mine is 24 years old
and has the old shifting system.shall i try camagnolo vs shimano?is it amatter of taste?
are they both same level but only other way?
shall ibuy that bike and forget this "religious" discussion? please help.
O.J.
Posted on: 15 October 2004 by Deane F
I'm referring to my road and track racing from 20 years ago - but in those days there was no question about whether Campagnolo was the best. If one had the money one bought Campag because it lasted and worked.
I seem to remember that Campag didn't bother with change for the sake of it either. Their range stayed the same unless a new product could offer a distinct improvement. (Like Naim)
Deane
Posted on: 16 October 2004 by long-time-dead
o.j.
You should buy the bike.
The setup of the geometry will be far more important than the manufacturer of the groupset.
If it fits like a glove - it will be ideal.
I use Shimano Ultegra throughout but looked at a bike using Campagnolo. In the end, it was the bike's "fit" that was the deciding factor for me.
You will love the new method of gear changing using the brake lever - I was a little sceptical at first but now that it is second nature, it is indeed MUCH better.
Posted on: 16 October 2004 by o.j.
Thanks for all comments.What idid not Know (never had one of those new gear shifter systems)is the circumstance that normally the hand is placed (nearby) allways a b o v e the gear shifter.they told me today in the shop.
so the only (theoretical)benefit of shimano is
that it is possible to shift gears u p while braking (think this is a non real situation)
so i will go on monday for the bike with campagnolo centaur.
O.J.
