Should Credos Hiss?
Posted by: P on 16 August 2000
I have recently upgraded to Credos and also a 72-hicap-180 -naca5.
At rest (?) - From 1/2 to full volume there is a discernible low level hiss from both speakers - can anyone tell me if this is normal ?
Both my Hicap and 180 tend to buzz and at times this becomes quite violent before dropping back to a background level -is this also normal?
All gear is less than 9 months old.
Pierre
Posted on: 17 August 2000 by Former member
It'll depend on what input is selected. The preamp has a high overload margin (40db) and quite a lot of gain that is not normally used.
Vinyl is noisier than Line (CD) because of the higher gain.
Any Line input will be noisy if there's nothing connected, because the "source impedance" is infinity, but as soon as you connect a device it will drop.
1/2 to full volume is more gain than you are likely to ever use, unless you have a very low-level source, so I'd have thought on CD/Tuner hiss at this level is more academic....
My system produces a very faint residual hiss on CD at normal listening volumes when head is close to the speakers - noticable at 1', just there at 2' and gone at 3' distance.
If your hiss is "dirty" i.e. tainted by faint mains hum/harmonics, its likely earthing or cable routing....
[This message was edited by Peter Chappell on THURSDAY 17 August 2000 at 09:20.]
Posted on: 17 August 2000 by Frank Abela
It's fairly normal for Credos (or any easy-to-drive speaker) to hiss at between 12 o'clock and full volume, on any Naim amplifier, and more so if connected to a high gain input like a phono stage or via the phono boards. The amount of hiss will vary depending on the quality of the amplificaton.
My Audio Note speakers are extremely efficient (94db which translates as about 3 times louder than normal speakers for the same given input) so I used to have to mute the output from my 82/hicap/250, which would reduce the hiss completely when leaving the system to idle.
Your description of the buzzing from teh components is not completely clear, but it seems like this is also par for the course. Occasionally, the mains supply will be more or less dirty than usual. Some amplifiers place a choke-type filter to clean the input to the mains transformer in the amp (as I understand it). Naim do not do this because their extensive tests with mains filters (internal and otherwise) have had seriously derogatory effects on the sound quality of their amplifiers.
Therefore, they have decided to live with the variable mains quality until they devise a filtering method which works. The effect of this is that sometimes, the dirt in the mains hits the resonant frequency of the toroidal transformers in the amp/power supply, causing it to vibrate more than usual.
The transformers are dipped in wax to circumvent most of this, but sometimes the sheer energy coming into the amp is enough to make the vibrating audible. The variable nature of this dirt is such that the transformer will start to 'sing' for a few seconds and then go quiet again.
Sometimes, when the electricity board is going through a particularly bad patch (courtesy of lots of appliances being in use in the area), the humming can keep coming and going in waves. The transformers in the Hicap and 180 are different so they should vibrate at different frequencies, but it wouldn't surprise me if the humming would be coincident in both cases at once. I also believe that the smaller Hicap case damps the huimming a bit more, but it still happens.
On the other hand, if the vibrating/humming were continuously apparent, this would probably be a fault.
Frank.
Actually Frank, the transformer in the 180 is exactly the same as the one in the Hi-cap.
Posted on: 17 August 2000 by P
Thank you all for your kind help and information.
I conducted the same test as Peter at normal volume at 1',2'& 3'and acheived much the same result, so am happy it seems normal.
From what Frank says about the buzzing -I guess I just have a poor mains supply - I have tried switching off all appliances in my house when the bad buzzing starts but to no avail. Would installing a dedicated spur and/or earth help with supply fluctuations ?.
Thanks again - P.
Posted on: 18 August 2000 by kevinl
My system comprises CD2, 82, 2*HiCap, 250, Credo. The Credos have been with me since CD3, Nait3, 92, 140,102 upgrades.
I have to say that over the years, I have been acutely aware of hiss coming from the speakers. However, I don't believe that this is predominantly the speaker's fault. They are moderately sensitive (88db I think) speakers, so any hiss in the system will show through.
The biggest contribution to hiss in my system is without doubt the preamp. As I've gone from 92, to 102, to 82, the hiss has dramatically decreased. With the 82, the hiss is virtually inaudible from my listening position. With the 92 and 102, I could sometimes (depending on background noise) hear the hiss from my chair. Also, the 82 is the only preamp I've owned where the mute button actually decreased the hiss level.
So, yes, the hiss is normal, but it's not the speaker's fault. I previously owned Rega Kytes (now sitting in our bedroom with a CD3 and Nait3) and they hiss considerably more, due to higher their sensitivity and the design of the amplifiers.
Some people are more sensitive to hiss than others. I find it bothers me, but it cannot be heard when there is music playing, so put some music on!
kevin
