Advice Please...
Posted by: Naheed on 23 October 2000
Undetered by previous encounters what are everyone thoughts on the upgrades detailed below:
Current Setup:
MM Stage 5/DAC 3/102/napsc/hicap/ixo/2* 140s/sbls.
I WANT THIS APGRADE TO KEEP ME HAPPY FOR AT LEAST 2yrs !!! rather than the usual 2 months...
naheed...
Posted on: 23 October 2000 by Rico
why did you omit CDSII/XPS/82/Hicap/ from the voting list?
You're definitely on the right track with working on Front End and pre upgrades. YMMV, and must be determined via careful demming.
Rico - musichead
Posted on: 23 October 2000 by Naheed
Rico, i thought if i go for the supercap/102, then the next step would be straight to the 52...
naheed...
Posted on: 23 October 2000 by Phil Barry
Have you considered going to a 250 to replace your IXO/140/140?
Other than that, what's keeping you from being satisfied with what you've got - i.e. what do you want to change?
Alas, I suspect (based on personal experience) that the change you need to make to keep you satisfied for 2 years is not in the equipment.
Regards.
Phil
In that case it looks like CDSII, with a sideline dem of the 102/SC... as long as you buy the CDSII.
Rico - musichead
