I've just bought a Minidisc player & am trying to connect it to my setup. Playback is fine, but when I try to record I am getting virtually no signal strength to the Minidisc. I have tried taking the Output from both 4 & 5 (using 5-Pin DIN to Phono). I have tried connecting the Minidisc to my TEAC 2nd system successfully & get full signal strength. Any idea what the problem can be?
Do you think a Flat-Cap will have a noticeable benefit on my CD3.5, 92/90 setup?
Posted on: 30 October 2000 by ian
My Headline Amp works perfectly well from both 4 & 5, but the Minidisc just doesn't get a signal. i keep moving the MD player between my NAIM & TEAC systems, no signal from the NAIM, perfect signal from the TEAC.
Very confused!!!!!!
Posted on: 30 October 2000 by Martin Payne
Presuming your TEAC has phono outputs you will be using different cables for the two amps.
You must use a din-to-4-phono cable for the Naim. Are you?
cheers, Martin
Posted on: 31 October 2000 by ian
thanks Martin
i realised last night that the wiring must be wrong & found that both my 5-pin-DIN to Phono leads were wired for Input not Output. i re-soldered one of them & i'm now up & running.
Are you saying that if i had a fully wired 5-pin-DIN to 4 Phonos, it would act as an all-in-one cable & therefore only take uo one connection (4 or 5 on a NAC 92)?
ian
Posted on: 31 October 2000 by Former member
Ian
That's right. You only need one cable per record input. I have a 4 phono to din that I got from chord.
So on your 92 you can connect a tape deck and a minidisc.
Matt
