Harmony One Remote & nDAC
Posted by: HuwJ on 20 June 2010
Hi,
Now that I have my nDAC up and running and my Mac, Squeezebox and Pioneer LX08 BR player (sounds pretty good too) running through it I have tried to set up the remote so that it changes the input as appropriate (on the Naim remote buttons 7, 8, 9, 0). While I can set the first position on my SuperNait to the correct input (eg: 1 for CD, 4 for Unity Gain) I can't work out how you can then input the pre/correct nDAC input after that - it does not seem to want to allow me to include further SN commands (although I could add in other equipment)/
Anyone hit this problem and know how to overcome it?
Huw
Posted on: 21 June 2010 by pcstockton
the manual tells you how to "lock" an input.
your answers are there.
