Logic - Logic System
Posted by: Martin C on 22 November 2002
Hi there,
Not sure that how many of you are into Japanese techno-pop, i.e. Yellow Magic Orchestra or YMO (perhaps R. Sakamoto would be more familiar to you). If you are into Kraftwerk, you won't be disappointed. They have numerous collabration between their members with the 80's band Japan.
Logic - Logic System are very impressive electronic music, I used to have a vinyl before, before I have tried to find the CD, I have no luck so far, can any of you help. Especially the Japanese naimees!!!
By the way, I am also tried to locate the triple CDs, Ruby trax, which different band cover other's song, like Tears For Fears covered Bowie's 'Ashes To Ashes', Manics covered ' Suicide is painless'. Let me konw if you know where to get the mentioned CDs.
cheers
Martin
