Nac 92 Phono cards
Posted by: syd on 10 March 2002
hi all, I hope you can help me with a couple of queries I have. I recently bought a NAC92/90 pre and power second hand. Brilliant sound but can anyone tell me hoe you tell the difference between the MC cards. The manual mentions 3. 323S,323E 323K. The cards are marked 323/1. Also is it possible to run the 92 from a SNAPS or does it have to be HICAP or better. Thanks for reading
