Digital Interconnects and the job of DAConversion
Posted by: Massimo Bertola on 26 January 2009
Hi,
which Digital cable do AV people use between DVD5 and AV2 other than the DC1?
Has anyone experimented between DVD5's analogue out and AV2 doing the DAC instead?
I am very curious, though I'll soon be able to do the test myself since I am waiting for my DVD5 to arrive.
Thanks for all opinions.
Posted on: 26 January 2009 by Gordon McGlade
Massimo
The DVD5 analogue outputs are for use as a stereo source or multi-channel DVD Audio playback which you can connect to the AV2. For DVDs, Dolby Didital, DTS etc can only be done in the AV2 NOT the DVD5 therefore you need to use the Digital output from the DVD5 to the AV2.
Gordon
Posted on: 26 January 2009 by Massimo Bertola
Gordon,
I was meaning on stereo material, such as CD, but forgot to specify.
Anyway, I have found a number of posts about the subject...My usual habit of writing before reading.
Massimo
Posted on: 27 January 2009 by Massimo Bertola
Gordon,
I contacted you privately for a different matter, but perhaps my server is not working..
Can you please try to send me an email?
Massimo
