135's on kans?
Posted by: Justin on 14 February 2002
I had an opportunity this week to play around with a couple of 250's on my Kan II's (bi-amp, not active) and I can say that it was not a win-win situation. What the Kans gained in bass extension they gave up in midrange fullness. It was a bit of a suprise to me. In the plus column I could follow bass lines better which is a real asset for speaker that struggles at 65 cycles. But, the midband seemed to thin out a bit just where the Kans are already a bit thinner than I like. I liked what two amps did to the bass (suggesting that the Kan II's really could "use" more power down there), but the midrange tradeoff is unacceptable). i suspect it is an impedence issue.
The question is, what about 135's on kans? Has anybody done this? What do you get in going from a 250 to 135's?
here's everything I'm looking for, any one of which would be acceptable, two of which would be gravy:
1. more bass (Ha!!!)
2. A fuller midband
3. a smoother top-end.
I do NOT need more detail or a more analytical bent.
I know active is still an option, but I can't bring my Kans active without a LOT of work. The binding posts (as I just learned) are soldered to the cross-over board. So, I'm looking for an interim solution.
Anyway, here's hoping somebody has some experience.
Judd
