Sonus Faber Owners: How do you gnerally measure the Signums distance from the wall behind them?
Posted by: Jaybar on 22 September 2001
Do you measure from the back of the speaker? or from some other point? Thanks,
Jay
Posted on: 23 September 2001 by Jaybar
my distance is MUCH further out than 30 cm. My question was do you measure from the back of the speaker or from the woofer's front?
Regarding compatability with Naim gear, I only have the CD5 so far and it seems to work well with the Signums. I am using Spectral amp/pre-amp and MIT cables. I have not heard the Signums with Naim amplificantion, so I can't tell. I plan to do that in due course. U I was intruiged by your abaility to get a good match with the NAIT. I would have though Signum needed more power?
Jay
