DVD/CD Player
Posted by: Evan D. Jay on 02 September 2002
Can anyone recommend an inexpensive DVD player that has decent CD playback? Thank you.
Posted on: 02 September 2002 by Nuno Baptista
Meridian DVD player:They are good in home cinema and Hi fi
MY sistem : Naim Nait 5 amplifier,Nad c 540 cd player,B&W 601 speakers,Naca5
Posted on: 03 September 2002 by Nuno Baptista
You have Nad DVD´s .They are inexpensive but very good material
Posted on: 03 September 2002 by belsizepark
My sister asked me the other day.. anyone here know a very cheap one that is ok.. £100 bracket or lower?.. she hasnt got much cash...
Belsizepark
Posted on: 03 September 2002 by matthewr
For £100 try http://www.richersounds.com/cgi-bin/productInfo.cgi?sid=b5e33c596.123456&productID=5775
For £189 (you get improved digitial electronics for arguably better picture/sound + better connectivity) try http://www.richersounds.com/cgi-bin/productInfo.cgi?sid=b5e33c596.123456&productID=5258
Matthew
Posted on: 04 September 2002 by Mr_Sukebe
As already noted, they just don't seem to exist.
I bought a Pioneer 535 DVD last year on the grounds that the hi-fi press said it "sounded pretty good as a CD player".
Being fair, sounded OK when compared to an old Marantz CD52 se. In comparison to my Arcam 7se, it gets completely murdered.
In addition, did some experimentation a few months ago and listened to DVD players upto £700 (Pioneer & marantz), comparing them to an Arcam CD72. Neither of the DVD players got even close to the Arcam CD player.
So, my advice would be to ignore it's CD capability completely, and focus on just it's video capabilities. I understand that Tosh DVDs are great, and that's what I'd buy now, along with a good CD player.
Posted on: 05 September 2002 by pac
Define inexpensive...what is your budget?
Posted on: 09 September 2002 by Simon B
Belsizepark,
I can vouch for the Tosh - build is light but the picture is very good.
Simon
Posted on: 09 September 2002 by Allan Probin
If you can pick up a Toshiba SD9000 s/h great Video and very good Audio
Funny you should mention that. If anyone should be offered one of these from a seller in Essex I'd be very interested in hearing from you.
Allan
