HiFace & Foobar with Linux?
Posted by: Holty on 14 July 2010
I've just purchased a HiFace and Acer Aspire Revo.
Having as usual not completely read the small print it seems the great little Atom PC I have purchased actually ships with Linpus Linux, (which I have less then zero experience with)!
Before I go through the rigmarole of sticking Windows 7 on this has anyone used a HiFace with Linux? is it easy? a ball-ache? better?
Also would i need to run an emaulator such as Wine (which I have heard is notoriously awful)to run foobar with?
A bit technical i know, but any advice would be appreciated!
Posted on: 14 July 2010 by Guido Fawkes
Shame to downgrade to Windows - I don't think M2Tech has released a Linux driver yet though, but at least you can delete Windows and upgrade again if they ever do.
Posted on: 14 July 2010 by Holty
Ahh crap.. I thought this maybe the case. I think i'll partiton the disk and dual boot windows and linux Roll Eyes can't do without the hiface
Posted on: 15 July 2010 by Eloise
There are no drivers for the HiFace under Linux.
While (I think) Foobar will run under WINE on Linux, you'd be better off with a Linux playback application or run XBMC or MPD.
Not sure if it's possible - but can you return the Acer - maybe cheaper to look elsewhere than buying a Windows 7 license. Or look at alternatives to the HiFace.
Eloise
Posted on: 15 July 2010 by {OdS}
From the m2tech website:
"Presently, Windows XP, Vista and 7 Windows drivers are available. Soon available also Mac and Linux drivers."
I guess you'll need to wait a bit then Frown
Posted on: 15 July 2010 by Guido Fawkes
That is bit out of date - there are Mac drivers available, but Marco hasn't had time to write any Linux drivers. They are only a small company, but a very good one.
Posted on: 16 July 2010 by Holty
Hey people! thanks for all tips!
I bit the bullet and ahem 'aquired' a copy of Windows 7 and stuck it on the Acer Winker
I have been reunited with my HiFace Big Grin
Posted on: 18 July 2010 by tyk263
Hiface has problem working with some AMD-based motherboard which your Revo is based on. You need to get confirmation with M2Tech.
Posted on: 18 July 2010 by Andy S
Umm.. the revo is based on an Intel Atom with Nvidia chipset. No AMD at all.... Winker
