The eagle has landed!!!!
Posted by: Timbo on 10 September 2001
Picked up my new 52 from the dealers on Friday. Got it home and connected up, sounded a bit cold and brash + the motoried volume control was a bit noisey, not unexpected. However when I flipped over to the phono channel the right speaker cone was popping in and out, oh dear what could be wrong. I swapped channels with the phono leads and still did it on right channel, disconnected phono leads - still the same. All other inputs were OK but was also getting this output on the tape loops. So labouriously disconnected it and decidied to check inside. I found that all the rubber feet were screwed in tightly but didn't meet the case, couple of millimetres gap. Took out the inside tray and took out, checked over and re-seated the phono boards. Had a quick scan to see of anything else was adrift (sure is a lot of electronics inside) and put it back together, this time made sure rubber feet were screwed in properly. Connected up and all seemed fine perhaps the car journey loosened some bits, it is a 90 mile round trip to my dealers.
This prompts the questions: should Naim fit and check phono boards before it leaves the factory, should the dealer be able to check correct operation - although dealer can't be expected tp possess every single type of cartridge to do this.
Now the positive bits
After checking all was fine on Friday night I was up fairly early Saturday morning and first thing I did was to give a record a spin to check out if the phono boards were still OK. The difference in sound quality was huge, my god only after 12 hours. So after a couple of hours music I had to go out. Saturday evening still better. Last night had about 5 hours of music from CD, phono and Dat and I was amazed at how articulate the thing was, like my old 82 but more relaxed, even arrogant at the way it portrayed the music. Trouble is a crap recording sounds like a crap recording. After Friday nights episode I haven't relaxed with it yet but things seem to be getting better.
Tim
