Want Better Sound from Your PC?
Posted by: J.N. on 22 October 2008
Fancy an active Isobaric (oh yes, with a 'C') system on the cheap?
I've just got one of these:-
Sub in situ. Back of top driver visible through the metal grille. The bottom driver output vents through a tuned port back to the top of the cabinet:-
Satellite showing mid and top drivers:-
Satellites and controls (wired and remote) in situ:-
Detail of supplied controls:-
Comapred to the usual boom-box systems for PCs the bass sure goes deep and clean and is nicely controlled and tuneful - spec'd down to 32Hz!
Good clarity attainable in the mid and top too thanks to the tone controls.
Eighty quid delivered, from Play dot com.
John.
John.
