STUPID QUESTION TIME
Posted by: AL4N on 20 January 2004
Is it possible to convert a document in Publisher to a jpeg file or something else in order to upload the afore said mentioned Publisher document to Sony's imagestation site?
Posted on: 21 January 2004 by AL4N
any-one?
Posted on: 21 January 2004 by monkfish
Hi
Sorry no experience of publisher but one way round it would be have the document open, then to tap the "print screen" key, then open paint or any other graphics program you use (photoshop, mgi, corel etc.).
Then go "edit" then "paste" or press "ctrl" and "v" which is the keyboard shortcut to paste.
This then opens the screen dump in the program you chose and you then save as what ever file type you want. hope this helps
Jim
Posted on: 21 January 2004 by Rasher
If you have Acrobat, you can save (print) it as a pdf file, then open it in photoshop and convert it from there to a jpeg.
Long winded, but it is at least a route.
thank you both. Smile
Posted on: 21 January 2004 by Former member
I was gonna suggest both those methods (honest!) but didn't have time to reply this morning.
Just like to add that if you don't have Adobe Acrobat, you can create PDF files for FREE without it. Go to http://www.pdf995.com and download the free programme. It works very well, just set something up as if you are going to print it then send it to pdf995 instead and hey presto, you get a PDF. I use it a lot, great tool.
Sean
Posted on: 21 January 2004 by Berlin Fritz
Why is a female swan known as a Bic ?
Fritz Von Roteaclassicinanattic
Posted on: 21 January 2004 by Derek Wright
cos it is a pen
Derek
Posted on: 21 January 2004 by long-time-dead
and here's me thinking it was because it is mainly white with orange at one end and will rip your face of if you are not too careful near it....
Oops, that the Bic Razor I was thinking about !
