Nautilus and Metal Domes?
Posted by: naimless! on 09 April 2002
Anyone with a similar system able to rock-out with material over the 9 o'clock position? I've had the system for about 4/5 months now so its well run in and I'm mostly hapy with it...but I sometimes find the top end very bright at high volume such that the sound is quite grating. i've noticed differances in temperature can have an effect, because during the winter months when the room was colder the sound could almost sound quite metallic/digital. Wonder if its the Nautilus metal dome tweaters? or is this just too loud? I got to 10.30 with cd3/nait/kefq55's? The speakers are about 2/3 months old - still running in? thanx pete.
Room is also quite bright with hard surfaces and a solid wood floor. size 16' by 16' approx
CDX/XPS/102/NAPSC/180/HI-cap/NACA5/ NAUTILUS 804
Posted on: 09 April 2002 by uem
Naimless,
I experienced a similar problem, with a different systen, though.
My dealer gave me a different interconnect between my Cd2 to the 82 to try,(I think it's a Van De Hull - DIN-variety, of course, completed by my dealer): it sounded more pleasant, less harsh, and still very transparent: just the way I liked it.
Needless to say, "cable-plays" are an endless story, with lots of trial & error, but it may be worth the effort.
Urs
Posted on: 09 April 2002 by Matthew T
Naimless,
I have a very similiar system to yours (just don't have the XPS). I have just added NAPSC and Hicap and have found that the harshness I was experiencing before has mainly gone. I have a carpeted room with a reasonable amount of furniture so plenty of acoustic disturbance.
You might find that pulling the speakers away from the rear walls further might improve the top end. I noticed at the dealers when auditioning that 4-5' opened up the top end alot, I am stuck in a small room so have them 18" off the rear walls which is far from ideal. Also what are you mounting you CDX on, I had a big jump in performance when I went to my DIY stand from the previous.
Matthew
Compared to naim speakers the nautilus are much less in your face or harsh, probably look to the amps first.
Matthew
Posted on: 09 April 2002 by Alex S.
I ran a CDX/XPS/82/SC/250/805s for a year. Now the whole lot has gone, but to be honest I'd have quite happily kept it all apart from one thing: that Godawful metal dome tweeter.
Please don't take this personally but given all the song and dance about the Nautilus technology I think the tweeter's crap. I blew up one and imploded 2 in the year I had them. My dealer accused me endlessly of just prodding them with sticks, but at least he replaced them under warranty. I'm sorry to say that when you take one apart its obvious they cost about 50p to make, regardless of any R&D.
That Kevlar midrange is a marvel but with a 250 the 805s needed a lot of work to tighten the bass and improve the treble. With a 180 the problem could be worse.
DNM speaker cable helped me, perhaps you could try that. Also I'd get the 804s onto granite plinths from hne, Base platforms (if you have a level floor) or Mana SoundBases.
BTW 11-0'clock on the dial for me = blow up!
Alex
Posted on: 09 April 2002 by bdnyc
Naimless-
I use a full Naim system with N 804's. The B&W's can be a nice pairing with Naim systems, and if you search the forum, you will find many useful posts on these issues. For what it's worth, here are my main suggestions.
The B&W's, like many speakers with metal dome tweeters, can be a bit bright in certain instances. The exact positioning of the speakers makes a huge difference with these designs, both for the overall tonal balance, and in particular, the angle of toe-in effects the high frequency balance. You might try to have them less directly angled at the listening position for a broader soundstage, and a bit less treble energy.
Secondly, the B&W's do take quite a long time to fully break in. In my case, I found that the treble became very open and extended without the propensity to harshness only after a full summer of use. The supplied spikes for the speakers are certainly not the last word in support. You might experiment with supports. In the US, SoundAnchors makes dedicated stands for the B&W's that are highly regarded, and reasonably priced.
I found that my system sounded best with my NACA 5 single wire run feeding the bass terminal, rather than the treble terminal. I use a short run of NACA 5 as a jumper instead of the supplied B&W jumper to go from the bass up to the tweeter. This wiring gave more control and power in the bass, and might tip your tonal balance a bit farther down from the top. Finally, the B&W bass drivers can come a bit loose on the front baffle. I tighten mine about once every three months to get a tighter bass response.
Best wishes and good luck.
Posted on: 09 April 2002 by garth
I recall reading a very favorable review of 803's in The Absolute Sound and their one criticism seemed to be that pushed beyond a certain volume their performance was abit compromised.
Garth<
Posted on: 11 April 2002 by naimless!
thanx all...few ideas there. pete
