The time has come.... New Cartridge time
Posted by: Ron Toolsie on 23 January 2002
Given the quality of the rest of your system, you'd be mad to skimp on the source! I wouldn't sell the dead cartridges as near mint, but I would definitely investigate the better cartridge options that are out there.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
best regards
Dev
with the high end system that you have i would guess that the higher DV's would work extremely well and take advantage of your superior components downstream.
happy hunting...
enjoy
ken
What are the other likely candidates? Anybody with experience with the transfiguration spirit3 or the clearaudio Victory?
If you are not too fussed about dealer support you may wish to consider picking up a Helikon SL or Dynavector XX-2 in the UK. They run to about $1100 for the XX-2 and bit more for the Lyra. Of course, you'll get a rebate for your old Dyna, sothe XX-2 will be sub-$1k. Either way, they are far cheaper than in the US (well something has to be..)
I use the XX-2 in my system (similar to yours just passive) and its a very good cartridge.
The Helikon SL is also great, and at its price, no complaints (I use it). Incidentally, Lyra also makes the Arkiv B, and they claim the Helikon is better.
>...I do not necessarily wish to pursue vinyl to
>the extreme unless I can be convinced that it is
>staggeringly better than the CDS2.
You will young Toolsie,... you will.
Ron, do you ever travel to Dallas, TX? I use a DV XV-1 in Armageddon/LP12/ARO and even with my lowly mid-range Naim amplification it's breathtaking. With your set-up, well...
Come on now, south east Tennessee isn't TOO far from Dallas, is it?
Best Regards,
Mark Dunn¡
Haven't made a direct comparison against an XX2 or Arkiv B but have heard both on other systems and was impressed.
Arthur Bye
We find that the Ortofon KontrapunktB is very good value for money at £750 (setup is critical with this cartridge, but gives good dividends). The Dynavector XX-2 is great for £1000 too.
You probably know how highly I rate the DV Te Kaitora.
Frank.
apologies if you have already done this to death, but can you post a few words on the differences between XX2 and the Te Kaitora (in my language, this means "the one that takes all")
many thanks
enjoy
ken
