Wall bracket fixing blocks inputs
Posted by: kevinrt on 14 December 2009
Hi
I wonder if anyone else has experienced this problem and found a solution.
I recently bought a 32" Panasonic LCD from John Lewis and at the same time purchase a tilt and swivel wall mount.
The problem is that the plate that is attached to the rear of the TV blocks access to some of the input sockets. Is this common with wall mount fixings.
The affected sockets are not ones I need immediately but I can see I may want to use them in the future.
Any ideas.
regards
Kevin
