AV2 problem
Posted by: Neil Bennett on 06 November 2009
Recently I've experienced a problem with the AV2. It's left in standby but used relatively infrequently. When it is, there's no sound through any input, but if switched off and immediately on again with the power switch at the back of the unit, it's fine again, till the next time a day or two later.
Any idea what's wrong?
Neil
Posted on: 07 November 2009 by Boj
I have experienced the same problem mostly when there is power supply shock. I have ups for my pc network, which records every shock and most of the times the av2 stops processing the digital signal at the same time.
Posted on: 09 November 2009 by AV@naim
For this issue, check you have the latest firmware first:
http://forums.naim-audio.com/e...8019385/m/1382966617
Boj: I am confused by your use of the word "shock". I assume you mean overvoltage/brownout transients?
What is your location? UK standard is +/- 10% VAC max.
Posted on: 11 November 2009 by Neil Bennett
Thanks AV@naim; I can't get into that link you've pasted/don't have permission, apparently. Can you advise the firmware version I should have?
Neil
Posted on: 11 November 2009 by AV@naim
Try this public one: http://forums.naim-audio.com/e...2929996/m/4372966617
Posted on: 17 November 2009 by Boj
Yes, I mean overvoltage and yes. I live in Sofia, we have standards too... in theory.
