Stylus Cleaners
Posted by: John on 08 October 2002
I need a stylus cleaner but have no idea what to use. I have read some of the information on the Record Research LP#9 and Zerodust but am not sure how well they work. Someone has also recommended using Windex with a makeup brush and to pull a very fine piece of sandpaper under my sylus every 6 months. I get the shivers thinking about doing this with my XX2. What do you use? recommend?
John
John
Posted on: 08 October 2002 by blythe
When I bought my LP12 about 15 years ago, Derek of NAF Loughborough (then, Sound Advice) gave me a piece of "green plastic" which I guess was an EXTREMELY mild abrasive. I still use it to this day!
Perhaps when I have my new Dynavector fitted tomorrow, I'll ask him if ti's still working as a cleaner......
I'm not sure about what grade of sandpaper would be equivalent!
Any info I find out, I'll post :-)
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "not today"?......
Posted on: 08 October 2002 by Tarquin Maynard - Portly
Hi there
Linn recommend a vibrating pad type affair. I use one on my Arkiv ( and also green "sandpaper!!).
The vibrator job is made by audio technica. No doubt they call it something posher than my crass description.
Mike
Mike
Posted on: 08 October 2002 by syd
This was the green stuff given away by Linn many years ago after noticing how effective the very fine sandpaper on safety match boxes and match books was at cleaning a stylus. I beleive at some shows in the eighties they gave it away with books of mastches. It was also a freebie with Hi Fi Review and I still use mine. It has been used over the years with Nagaoka, Linn and AT cartridges and was/is very effective. Indeed it got a recent mention (and slagging off) in HI FI World by David Price so you can appreciate that this is one of the best endorsements I can think of. To use it all you do is pull the rough side towards you with the stylus on it just once (David Prick mentioned People Scrubbing their styli away but this is crap)at the end of an LP side. Also an Audio Technica Vibrating stylus cleaner used at the end of a session will keep your stylus good for many years.
Yours in (well scrubbed)music
Syd
Posted on: 08 October 2002 by Bob McC
The Audio Technica vibrating cleaner which I use has not been made for many a year and one recently went on e-bay for 42 quid!
Posted on: 08 October 2002 by Paul Ranson
I think the Zerodust thing is very useful for the sticky moments.
But I have an AT637 for those other times. I don't know whether anything equivalent is available new.
Paul
Paul
Posted on: 08 October 2002 by mykel
that Audio Technica broke the only mold for the AT 637 and never replaced it. Mine is still working just fine.
regards,
michael
regards,
michael
Posted on: 09 October 2002 by Richard Dane
Discwasher used to make a very effective stylus cleaner. It's a very neat package being housed within a lovely little wooden case. It has a head with very densely packed fine bristles on one side and a magnifying mirror on the other.
I've been using mine for 16 years or so and it still does the job very well (the wood has started to take on a nice patina too...). It's possible you may find some NOS examples being sold on the net - check out some of the big US vinyl sites.
Posted on: 09 October 2002 by David Stewart
is what I use. Its a very short bristled stiff brush to which you apply a drop of cleaning fluid before gently pulling it through under the stylus. Same principle as the 'sandpaper' but I assume less abrasive. Seems to be effective too.
Posted on: 09 October 2002 by Malcolm Davey
I use a vibrating cleaner that was made by Goldring, had mine for a few years but still seems to be doing a good job.
Posted on: 09 October 2002 by jpk73
Does it cause damage to my Troika...?
- Jun
- Jun
Posted on: 09 October 2002 by Frank Abela
Lyra make a cleaning solution called SPT (hence often called spit). It comes in a box with a fabulous brush, the like of which I haven't seen elsewhere. It's not cheap but I forget the price.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Frank.
Posted on: 09 October 2002 by Tarquin Maynard - Portly
Originally posted by markharro:
Where do I get myself some of this green sandpaper?
email me your address and I will send you some of mine ( assuming my children have not used it to polish the cat etc.)
Mike
Posted on: 09 October 2002 by John
My local dealer told me to never use stylus cleaners as they can cause damage to the glue holding the stylus. My DVXX2 info sheet states the same. I suspect people use the products based on the results (which I am sure are good) but is there a risk to the glue holding the stylus? Is there a difinitive answer out there?
Posted on: 09 October 2002 by blythe
I always thought that "glue damage" was as a result of using a liquid cleaner containing some kind of solvent.....
I doubt "all" stylus cleaners could possibly damage the glue that holds the stylus...
Of course, I could be wrong :-)
Computers are supposed to work on 1's and 0's - in other words "Yes" or "No" - why does mine frequently say "Maybe"?......
