Can a Flat-Cap 1 Power a NAC 82?
Posted by: Jack911 on 19 February 2004
Or do you need a Hi-Cap as a minimum?
Posted on: 19 February 2004 by Jay
Flat cap will work fine.
Jay
Posted on: 19 February 2004 by mattbr
Originally posted by James:
But an 82 deserves at least one Hicap, preferably two.
James
Hmm...
but would 2 flatcaps sound better than 1 hicap ?
Posted on: 19 February 2004 by prowla
For sure 2 Hi-Caps will be better than 2 Flatcaps...
Paul Rowlands
Posted on: 19 February 2004 by Roy T
Super. . .
Posted on: 19 February 2004 by Carl Leermakers
...and you'll only need one...
......and a bigger wallet!......
Paul Rowlands
...but you're right - I've an 82/2xHi, and would replace them with a Super if I had the spare wonga.
Paul Rowlands
Oh hell - what about dumping the 82 and just going for a 552 then you won't even need a cap! I just saved you the price of a flatcap Roll Eyes
Posted on: 20 February 2004 by pslosarc
....I have used the Supercap auxiliary output to power the wife and it works great !!!
....sorry!!!
Posted on: 20 February 2004 by Jack911
Originally posted by ejt:
I think the interesting comparison is how using both channels of a FC2 would compare to using a single HiCap.
Anyone every tried this?
The Naim Connections Guide states on page 16:
"Sound quality will be severely impaired if power supplies are mixed. A flatcap together with a hi-cap for example. Similarly, both outputs of a Flatcap 2 should not be used simultanesously to power one preamp"
Posted on: 21 February 2004 by London Lad
The flat cap outputs are two different voltages (24 for pre and 22 for CDP) so its not a good plan earth loops aside.
Graham.
Not a lad any longer and not from London!
