Sweeping the grooves...
Posted by: Top Cat on 10 February 2001
Hi folks.
I'm looking for alternatives to the VPI supplied brush that came with my 16.5 record cleaner - having so far cleaned around 200 LPs, it's beginning to look a bit worn and in any case the bristles on it always seemed a bit on the thick side to really get inside those grooves.
I was wondering if anyone had tried alternatives, particularly any 'non-dedicated' brushes, e.g. fine filament oil-painting brushes (unused, of course) or similar - i.e. something that's easy to get hold of locally and that will be able to really clean those grooves.
Any thoughts, folks?
John
