cleaning the cd´s
Posted by: Nuno Baptista on 27 September 2006
Water is OK?Or do you use some special product?
Posted on: 27 September 2006 by Bob McC
any spray furniture polish.
Posted on: 27 September 2006 by Stephen Tate
hi,
I use Isopropyl alcohol on a clean cotton duster and lightly wipe across followed by a light buff to remove any residue left from the isopropyl.
Works perfect.
regards
Posted on: 27 September 2006 by Guido Fawkes
How to Fix a Scratched CD
How to Clean CDs
... or you could just play them.
