Unitiserve and Plug Player app
Posted by: rded on 28 September 2010
Hi All,
Does anybody know if the UServe and Plug Player iphone/ipod app are compatible with each other? The app could not detect the UServe and I am unable to "add a device manually" on the app interface.
Any advice/help would be greatly appreciated.
Posted on: 29 September 2010 by likesmusic
There's a free iPhone app called "UPnP Browser" by Oppian which looks around your network and provides information on all the UPnP compliant devices on it; this could help you find where your problem might be. hth.
Posted on: 29 September 2010 by rded
Thanks. I shall try this when I get back home later.
Posted on: 29 September 2010 by Eloise
quote:Originally posted by rded:
Hi All,
Are you wanting the PlugPlayer app to control what is played on the UnitiServe, or control playback on another device (i.e. UnitiQute) with the UnitiServe as the UPnP AV server?
If the former, (i.e. PlugPlayer controlling whats playing on the UnitiServe) then no it wont do that. It should see the UnitiServe as a UPnP AV server though so long as both are on the same network.
Eloise
Hi Eloise,
I would like the Iphone to be a client while using the Plug Play app, thereby streaming music from US to Iphone.
Posted on: 29 September 2010 by divuk83
Give plug player a bit of time to scan for devices, it took ages for it to find my Uniti!
Dave
Dave
likemusic,
I downloaded the UPnP browser by oppian. It worked while at was at work but it could not detect anything at home. WTF! I've tried the Plug play app and UPnP browser multiple times. I even have the UPnP browser app on my Ipad and both of them could bot detect any wireless device at home, not even my Macbook Pro>..Could it be that I am using Airport Extreme as router and Airport Express as wireless bridge to the Unitiserve? But the N-serve app works properly though...
