DAC spec to match CDS2
Posted by: rich2513 on 30 June 2010
Keeping this simple, can anyone advise me as to what spec or config I need to run the dac in to match the sound quality of the CDS2. When I say sound quality I am not necessarily after ultimate detail and resolution but rather a sound that is analogue-esque, very sweet, musical and easy on the ears like the original CDS1 and CDS2.
1. would i need the XPS as well ?
2. can you use an older olive XPS ?
3. what would I need in the way of a low cost streamer ... would a SB touch be good enough ?
Sorry for the wadge of questions but I am having to make a firm decision as to whether to go for a dac now or a used CDS2 and wait 12 months or so for the file based world to develop a little more.
I gather that people have had great success using cheap old transports with the dac as well (Meridian 206 etc..). It's a shame that there's not a cheap dac-less naim transport that can be used in conjunction to keep everything neat and looking the same, maybe naim will soon develop such a thing.
Posted on: 30 June 2010 by pcstockton
Dont wait.... get the Naim DAC now. File based music is fairly well dialed nowadays.
I have not heard a CDS2 but I would guess a 555ps on the DAC would get you somewhere in the ballpark. Add a powerline and hiline and who knows??!?!?!
Yes you can use an olive XPS.
Any streamer will give you fairly good results. I would cobble together something for a toe dip until the Uniserve is available.
A Uniserve>DAC>555ps>Hiline will be pretty formidable i think.
Posted on: 01 July 2010 by Andy S
The stock nDAC is streets ahead of the old CDS1. It has better phrasing, midband detail and is more believable. It can be a bit harsh at higher volumes though. This is significantly improved by adding an external power supply.quote:Originally posted by rich2513:
Yes. You can also use a CDSPS (old CDS1 power supply) if you get the cable fergled by Naim (nominal cost). This is how I run my nDAC and it rounded off the harsh edges very nicely.quote:2. can you use an older olive XPS ?
Hmm... that's a tough one. Define "good enough"? I can't tell the difference between transports (although I remain open to hearing differences) many others can. I have a feeling that if differences are there, they are minimal (cue people telling me I'm cloth eared or my system isn't set up properly). Trying stuff out isn't too difficult or expensive though.quote:3. what would I need in the way of a low cost streamer ... would a SB touch be good enough ?
If I were in your situation (and had the money
Posted on: 01 July 2010 by Thorsten_L
The Squeezebox Touch with the nDAC is IMHO excellent value-for-money.
The sound is really wonderful, coming, in my case, via ethernet-cable from my PC-harddisk.
Use an Ipod-Touch via Ipeng as a remote and boy, what a great sound coupled with great fun.
Posted on: 01 July 2010 by rich2513
It's a shame that naim don't make an HDX with no DAC and bigger drives.
I like the idea of the HDX interface and also keeping the music on one box.
The unitiserve could be good. Does anyone have a video of the naim hdx/unitiserve interface in action ?
Posted on: 01 July 2010 by Hot Rats
I have Naim DAC with new style Naim XPS. I source it with a laptop PC (Windows 7 x64) and M2Tech Hiface. I use Foobar2000 software.
For CDs I use a CDS2 with Olive XPS. I have compared the two and would say that the nDAC/XPS is marginally better.
Posted on: 01 July 2010 by Eloise
Well they kind of do ... the Unitiserve is a HDX with no analogue output and single 1TB (compared with mirrored 400GB IIRC) drive.
Eloise
Thanks Doctor..
IS the DAC combination as analogue and musical sounding ? Does it stand up to hours of listening ?
quote:Originally posted by rich2513:quote:Originally posted by rich2513:
Thanks Doctor..
IMHO it does. I find that the sound is just a little smoother and more musical than the CDS2/XPS combination. This is not a criticism ... The CDS2/XPS is a great CD player. I do find that imaging is better with the Naim DAC/Naim XPS combination.
I wonder if anyone can tell us how the nDAC/XPS compares with CDS3/XPS
Posted on: 01 July 2010 by gone
quote:Originally posted by Doctor Jazz:quote:Originally posted by rich2513:quote:Originally posted by rich2513:
Thanks Doctor..
I suspect it will depend a bit on what it is fed with (although there are some that say it shouldn't make a difference). With an HDX, the DAC/555PS is better than a CDS3/555PS IMO, but maybe it's not possible to extrapolate down to XPS.
IMO of course.
Since the UnitiSwerve is apparently an HDXmini, this, with an nDAC/XPS should be outstanding value, assuming its PSU doesn't pollute the mains
John
Posted on: 06 July 2010 by Skip
I listened to my own CDS2 with olive XPS compared to Kent's Naim DAC driven off my XPS using an Empirical Off Ramp driven by my MacBook Pro. The DAC sounded very good. Not quite as good as the CDS2, but close enough that you would not want to trade. Kent thought he preferred his DAC, but I would not have been happy with the DAC over the CDS2 without the XPS. With the XPS, the DAC sounds darn competitive, and probably wins for flexibility and future-proofness.
I was impressed enough with the power supply upgrade that I made my own investment in future-proofness and got a 555PS to drive the CDS2 head unit. Now it really rocks to the next level.
I wish I could make the comparison using the new power supply but Kent moved overseas and I know of no other nearby Naim DAC's.
Posted on: 10 July 2010 by Mike Smiff
[QUOTE]Originally posted by rich2513:
They sort of do, it is called a NS01, is £1,600 cheaper but you need to add a apple touch to control it as NS01 dose not come with a touch screen.
Lets face it how many HDX owners are going to use the touch screen for playback, they are going to use an apple touch now, right?
