Where should I put them?
Posted by: i am simon 2 on 31 May 2002
I dont want the comedy answer that I will no doubt get.
I have Ruark Epilouges, a little standmount speaker that was the best I could afford at the time, and I am yet to come across somthing that I can afford to beat them.
They are rear ported, and I am never sure how far from the back wall they can go in relation to how far from the side walls they are. I move them from time to time, but as I gain one thing I loose an other.
Any advise as to positioning relative to the walls would be good.
Simon
Posted on: 31 May 2002 by Hammerhead
Hi Simon,
Have a look at this link here
I did print off a handbook that Ruark produced for this reason (speaker specific). If I find it, I'll email it you.
Steve
Fellow Ruark-er
Posted on: 31 May 2002 by garyi
I heard a pair of floor standing ruarks the other weekend when i was do a function, they were on the end of some arcam stuff, sounded really nice.
Posted on: 31 May 2002 by J.N.
The simple answer is; that they're right where they sound right to you.
If you are experiencing bass INXS, close to the rear wall; try the old trick of packing the ports with drinking straws to reduce bass output.
Good luck.
