Amps for Isobariks? 135, Klout or another?
Posted by: mark dunsford on 22 November 2001
I'm also interested in any other experiences with power amps of the same calibre that work well with the Briks.
(I use a Kairn as a preamp BTW)
Cheers.
http://forums.delphi.com/n/main.asp?webtag=LinnProducts&nav=start
me? I'm happy with an old 250, I played Eric Bibb's 'Painting Signs' tonight and it is stunning.
Worth a look.
mikeh
No, the Kairn isn't thin - unless a Naim power amp is partnering. I am surprised your dealer allowed you to mix up the pre/power amps in this way.
IMHO, I prefer the more solid sound of the LK240 (or LK140 for that matter) than the Klouts. So, demo the following:
1) 82/Hi-Cap/250
2) Kairn/LK240
3) Kairn/Klout
I did hear an LP12/Ekos/Troika/Lingo/Kairn/Klout/Isobariks (final version) - it sounded immense, heavy duty and confident.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
My sound isn't thin, in fact its enjoyably warm but a little more control would not go amiss. The new amp(s) need to run loud without closing down after 5 minutes! Mind you my old Sara 9s closed down the 250 in less than 10 seconds!
I heard recapping changes the sound dramatically, so maybe not.
How much is the Mana Stealth and is it available yet? No details on their website.
The idea that you can't use non-Naim preamps with Naim power is untrue but it does depend which one. If the 250 hasn't blown up yet then I'm sure it won't. I ran a Dynavector L100 pre with a 250 for over a month without any problems (the 250 ran cooler than it did with 82 or 32.5/Supercrap).
If you're thinking about 135s then listen to the Dynavector HX1.2. I think the latter eats 135s for breakfast but that's only my opinion. Have a listen and then decide. I guarantee that an HX1.2 will not shut down before your eardrums explode.
Alex
I'm not sure if the Stealth if available yet so could be a long wait.
Klout seems a option but how does it compare to a 250, anyone? Crimsons were also mentioned as working well with Briks, anybody heard comparsions made with either the 250 or 135s?
Cheers.
Arranging a dem of either 135's or Nap 500's is easy.
You try and arrange a dem of a Stealth......you will be on your pension by the time it arrives.
If it's as good as you say, then great, but Mana needs to get the supply side of things in order or else it will only be the topic of conversation rather than an implement of listening.
How many have seen sold.......less than 5 I belive. Speaks for itself.
Mick
Give it a go!
Good luck
Goose
If this is the behavior you are experiencing, may I suggest that part of the problem is a mismatch between pre and power? The Naim pre bandwidth-limits the signal for the amp.
The Linn probably doesn't. So the amp is stressed into difficult loads, and shuts down. Probably wouldn't be an issue with easier speakers. But try to borrow any Naim pre and see if the amp doesn't last longer before shutting down (if it does at all).
--Eric
And that was with a NAIM, yes NAIM 32 preamp.
BTW I couldn't care less whether FATmouth or any other inarticulate individual believes Naim preamps are better than Linn preamps, in my system the Kairn sounds more enjoyable. ![]()
[This message was edited by Jez Quigley on TUESDAY 27 November 2001 at 06:47.]
I find a blinkered anti-Linn stance just as unhelpful as a blinkered pro-Naim one.
Alex
As for 'my bit of hifi is better than yours' attitude, surely people have realised it's highly subjective at this end of the hifi spectrum and depends on many factors, not least of all the way you personally like your music to sound. Sure there's differences but these can change according to system, room etc, etc. It's how you enjoy YOUR hifi that counts, its your money!
