Extra NAP 150 just for the centre
Posted by: dan scott on 06 February 2007
Hi everyone,
Do you think there would be any benefit in having an extra NAP 150 just to power my n-Cent? (Usually powered from a NAP V175 with a NAP 150 doing the fronts)
Dan
Posted on: 06 February 2007 by Jay
no.
Posted on: 06 February 2007 by dan scott
direct and to the point, cheers Smile
I didn't think it would, a 200 maybe but not more of the same. Cool on with the pre-amp hunt...
re: 200. for best results you want identical amps across all channels. that's what you've got already Winker
a pre is where I would put my money but the av2 is no slouch. maybe wait till it comes back from a service before comitting to another pre?
J
Posted on: 07 February 2007 by Frank Abela
If you want to improve the centre, the right thing to go for would be a NAPV145. This would release you for a 200 for the main fronts and switch your 150 to the rears allowing you to sell off the 175.
Posted on: 08 February 2007 by tonym
Spot-on advice Frank! I use a 145 to drive my Axess centre.
Don't underestimate how crucially important the centre channel is to good surround sound!
Posted on: 08 February 2007 by Adam Meredith
http://forums.naim-audio.com/eve/forums/a/tpc/f/7801938...932960807#1932960807
That'll be three.
