DAC+Majik DS =
Posted by: T38.45 on 14 February 2010
Hi folks,
we had some posts here about "whatsoundsbetter" a Linn Majik DS+DAC or a Akurate DS?
A german hifi magazin tested a Sneaky+DAC against Akurate. Winner was Akurate in their opinion... They mentioned that the source of DAC plays a fundamental role ( ok, I can confirm this!)
Would be good to hear if some of you did some benchs against Akurate as well!
regards Ralf
ps: i changed from 282 to 252 this week....Naim, thank you for this insides to music... simply not from this world!
Posted on: 14 February 2010 by rich46
[QUOTE]Originally posted by T38.45:
Hi folks,
regards Ralf
ps: i changed from 282 to 252 this week....Naim, thank you for this insides to music... simply not from this world![/QUOT
customers may never get the chance of comparing components in these combination, but there is a difference the dac is a hub, ive got the dac and it has 4 different inputs, cd transport/sacd for 16bit out put/ dab/and sonos, , thus improving all inputs not just cd allan
Posted on: 15 February 2010 by js
It's difficult to know why or where the issue is in that combo but their source comment may give a clue. There's a rumor that Naim will address this issue and show a streamer themselves at Munich. Nobody's corrected me on this so perhaps it's more than a rumor.
Posted on: 15 February 2010 by T38.45
What timeframe for streamer?
Posted on: 15 February 2010 by gone
Call me Mr Thicky, but isn't the UnitiQute a Naim streamer?
Posted on: 15 February 2010 by John Bailey
Yes but not with the 'engine' from the N-DAC....
Easily fixed. Buy an nDAC?
OK, how many boxes should be in the Naim streamer range? Is the UnitiQute a Sneaky? That leaves room for three more, or does it make more sense to bolt a DAC onto a smaller range?
Ah, the joys of product marketing....
I remember a thread a while back where someone took the trouble to list all the possible combinations of Naim boxes - how many more do we need? (I've already got far too many - Linn Klimax is starting to make sense from that point of view Winker
Two perhaps.
One in an XS case (built in Supernait spec DAC) with SP/DIF for connection to N-DAC for up-graders.
One in Reference case - built in N-DAC, upgrade with XPS2/555PS.
That should do it.
I'm kinda hoping this will have a better DAC - maybe a Wolfson chip - and I suspect it will need a 555PS. Plus the heavy old suspended brass chassis. But I'll be well impressed if they churn that out within two years, but we live in hope
Apologies to the OP - rather buggered your thread I'm afraid
This would be at Akurate level - with upgrade room to spare.
The Klimax smasher can come later...
Yes. Sorry. Dreamtime over.
Posted on: 15 February 2010 by Guido Fawkes
I heard the Akurate against a CD5i and preferred the Naim CDP - no contest IMHO. The Naim DAC sounded superb in the demo I heard and better than any such device I've heard - which only goes to show you should never believe anything you read in magazines: you have to listen for yourself - I'm not keen on the Linn DSs I've heard.
Posted on: 16 February 2010 by T38.45
Hi,
i want to come back to the NAIM streamer topic...
Does one has more infos?
Will they launch it in May in Munich?
tx
Ralf
Posted on: 16 February 2010 by js
The full sum of what I heard was that something should be shown in Munich.
