PS3 as a DVD player
Posted by: Wazza69 on 02 July 2008
Hi Guys,
I was thinking of selling my Panasonic EX77 Freeview HDD/DVD Player as I now have Sky HD and getting a PS3 to play DVDs (and Games of course). My main concern is the noise that it makes whilst playing movies as I can’t hide it away. Is it very distracting?
Thanks,
Waz
Posted on: 02 July 2008 by john R1
Wazza69, i don't find my ps3 noisey, in fact compared against the x-box 360 it seems totaly silent.
Posted on: 02 July 2008 by Former member
Hi john,
Hope you are all well up there in Essex.
I have been round a lot of friends that have the PS3 and some are more noisy than others.
Also some run very hot and some dont.
Regards to you and Mrs john Winker
Munch
Posted on: 03 July 2008 by TomK
My son's PS3 is virtually silent and doesn't get warm in the slightest. In contrast his X-Box 360 sounds like an old air conditioning unit.
Posted on: 03 July 2008 by Wazza69
Thanks Guys
Posted on: 03 July 2008 by Frank Abela
The original 60GB PS3 was variable in its noise depending on whether it had a Chinese or Japanese fan in it. The ones with Chinese fans were very noisy indeed (likened to a vacuum cleaner). I don't believe there's an easy way to verify which one you've got. It's pot luck. The latest 40GB version seems to have resolved this problem and PS3s are generally very quiet. Of course the 40GB versions can't play SACD and have only 2 USB ports at the front instead of 4, and they don't have the card readers of the original machines.
In the US they have an 80GB machine which does play SACD I believe. I do not know if those are quiet or noisy, but I suspect that since the US always gets the cream of the products, they're probably quiet.
Posted on: 06 August 2008 by Tuan
Originally posted by Wazza69:
Hi Guys,
Thanks,
Waz
My PS3 is deadly quiet and the PS3 is practically the best bluray player on the market since it is all software driven and get updated often. It is a living machine and will NOT be obsolete Big Grin
Posted on: 06 August 2008 by scottyhammer
its not very good for me as it doesnt seem to play multi region discs which i have many of ! Roll Eyes
You can recode any of your DVD using the divx format and replay on the PS3. It's easy!
Posted on: 07 August 2008 by scottyhammer
tuan,
i havent a clue as to what your on about ! please explain.
regards, scotty
Posted on: 07 August 2008 by Mike1380
He's basically talking about ripping the content of the dvd's that won't play, due to region restrictions, in a PS3 and then burning them onto blank discs in a different (and to my mind, inferior) form.
Frankly I can't say I'd be too enthused about doing that 143 times for the number of non-local region discs I have!
Posted on: 07 August 2008 by Frank Abela
Tuan, does divx allow for full surround sound transcription? I thought it only allowed stereo.
