Linn Saras Cannon connectors
Posted by: Ronnie on 31 March 2002
I need 2 cannon plugs for a good old pair of Linn Saras Any ideas must be mint
Posted on: 31 March 2002 by ejl
I'm not sure what a "mint" idea is, but if it's any help I've used Neutrik xlr 3-pin female plugs on Isobariks with good results. I ditch the big metal casing that they come with and use only the stripped-down socket with a rubber strain relief over the conneciton. You should be able to find a pair mail-order with a Google search on "xlr socket".
Posted on: 02 April 2002 by Andy Kirby
Hi Ronnie
Does your dealer not have any? If not, try one of the larger dealers like Grahams of London?
Andy
[This message was edited by AndyK on WEDNESDAY 03 April 2002 at 13:13.]
Posted on: 02 April 2002 by J.N.
My local Naim dealer is getting some good quality ones in for my Saras.
Call Graham at Basically Sound (near Norwich) on 01508 570829.
Posted on: 03 April 2002 by Andrew Randle
Maplins will have them if you can't find any.
Andrew
Andrew Randle
Currently in the "Linn Binn"
