Where did the bass go?
Posted by: JeremyB on 09 April 2002
Today I committed the cardinal sin of making more than one change to my system:
1. "finished" the dedicated spur (ie tidied up). This included some advice I saw on the forum (put the audio spur CB first in line for power, tightened the consumer unit ground (really loose - took 3 turns!)
2. Since the amps were powered down, took the opportunity to dress all 4 naim speaker cable plugs following the advice to have the prongs free to move in the plastic case. I can't find the original post about this. I left the centre screw slightly loose in each plug to ensure the metal prongs are free to move in the plastic housing
3. Adjusted TT level and bounce (since I had moved it)
So....
The change was incredible - I can only describe the sound as THRILLING incredibly dynamic, that 3D feeling of the music, realism and so much more music. But I didn't hear any bass! I thought this may be something to do with the TT, but something similar was also happening with CD.
Has anyone else experienced this? Can it be explained? I am confused.
Jeremy
