circuit diagram-naim110
Posted by: leslie on 04 October 2001
Does anyone have a circuit diagram for the 110? Can anyone id (1) the non tant caps (2) the tants
Posted on: 12 October 2003 by vidak
Originally posted by Andrew Dunn:
All NAPs are essentially the same as the NAP135. A schematic can be found here:
http://www.neilmcbride.co.uk/output-amp2.pdf
BTW, in this circuit, the overload protection stuff is not shown, so you will have some extra bits.
Andrew
NAP110 preamp power supply
Hi,
I would need some help restoring the preamp powersupply of a naim NAP110 (at some point this has been removed as it wasn't used). I guess all that has to be done is to connect a cap to the rectifier and then via the regulator to the DIN connector. Is this correct? What should the value of the Cap be? Exactly how should it be connected? Schematics, anyone?
/Vidak
