Ground switch
Posted by: Hans Vereecken on 05 May 2009
I have set my "ground switch" (back of the HDX) to "Chassis". Is this the best position?
Can I change the position of this switch while playing or do I have to switch the HDX off first?
Has anyone tried different positions? When should I go to "floating"?
Posted on: 05 May 2009 by Mike Smiff
You only need to go floating if you have a source component that provides system a earth such as a Naim CDP,a Naim tuner or a Linn t/t.
Posted on: 05 May 2009 by pcstockton
I am not sure if it requires a Linn TT, a properly grounded TT should work eh?
The Linn ,yes just one that sprung came to mind. Big Grin
