Cosmetics: Chipped paint on Naim casing
Posted by: Pierre Isabelle on 08 March 2002
Is there any good way to hide chipped paint on modern Naim casings?
-- Pierre
Posted on: 08 March 2002 by garyi
I found a matt black touch up paint from Halfords which does a good job of the edges and such like as long as you don't over do it.
Posted on: 08 March 2002 by Frank Abela
You could use black marker. The trick is to fill in the chip without going over the unchipped part of the box. If you do that, you'll see the touch-up. If you stay inside the chipped section it's pretty much invisible.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 11 March 2002 by Pierre Isabelle
garyi:
Thanks for the tip, but could you possibly find the brand name and colour number?
Frank:
Thanks for the tip. I will try it.
-- Pierre
Posted on: 11 March 2002 by garyi
Pierre.
I am a nice man, and thanks to the fact my rocker cover gasket on me car as gone south I will need to visit Halfords again ( alas I lost the bottle I had some time ago)
Posted on: 11 March 2002 by Chris Brandon
Garyi,
Besides the new gasket,a number of garages also supplement this with the "instant gasket" type stuff (just to be sure)
Chris
chris, cheers for that, the 'proper' one was 2 and half quid, not worth worrying about. although I rather hope this is the problem!!
I couoldn't find the exact bottle I used to have for the colour, its all changed, but I don't think its worth getting to anal over, just buy a bottle of black matt touch up paint, the one with the brush in the top, touch up only the scratch and no one wil be the wiser
