82 input question
Posted by: Alex S. on 10 August 2001
Why did a dealer tell me that I should use the Tuner input on my 82 for my CD player? He mentioned something about the standard CD input being buffered, is this true, and if so, does it matter?
ps I don't use a tuner.
Alex
I am using a cdx/xps (no other inputs used - until tommorow). The rest of the system is 82/Hicap/250/sbls.
IMO the cd input (2) is better.
Chris ![]()
Now, how tight are your locking rings?
Paul
I've swapped 2 & 3 about and most of the time think I can't hear a difference but at other times think that input 2 sounds marginally better.
Thanks for your replies.
Alex
...'cos it's closest of the DIN inputs to the 729 buffer stage (though the BNC inputs are closest--the only current preamp to offer this preference).
On the 52 and 102, input 3 does seem to sound the best (no Prefix power or record outputs, either).
All five DIN inputs are identical with regards to input impedance, feeding the time-aligned filter/buffer stage; what Mark (er, which Mark?) may have referred to was the buffered record outputs on 4, 5, & 6.
Dave Dever, NANA
