Deleting tracks and al***s
Posted by: docmark on 30 August 2010
I'm starting to pull my hair out. I've been trying to delete some tracks & albums using the Naim Desktop Client, version 1.5a, I believe. Nothing happens. The "Delete" under the Edit menu is greyed out. Can't delete anything. Any ideas?
Posted on: 30 August 2010 by Harry
Would this be with the HDX?
Posted on: 30 August 2010 by docmark
Sorry, yes.
Actually, the version of DTC I'm using is 2.0.7.1140
Posted on: 31 August 2010 by Manu
You have the right version.
Highlight the album you want to errase and right clic then Delete.
Posted on: 31 August 2010 by Harry
I had this issue in the DTC with an album which didn't rip properly. I deleted it using the HDX front screen menu (actually done in a browser over the network). The important bit is to then empty the recycle bin.
Posted on: 31 August 2010 by docmark
I found out what I was doing wrong - trying to delete some files from my NAS using the DTC. Doesn't work.
Posted on: 01 September 2010 by Billy Rubin
Confusing. So how do you do it, then?
Posted on: 01 September 2010 by Phil Harris
The HDX / NS0x / UnitiServe can only delete music from their own internal drives or from network stores which they "own" and you should not manually add / delete / modify data on a network store.
Network shares are not managed by the server and if you wish to delete music from a share then you just delete it using Windows Explorer.
Phil
Posted on: 01 September 2010 by docmark
I'm using an Iomega home media drive as my NAS. Seems to work well, though sometimes difficult to delete music. This drive has many hi-res files, which I loaded by dragging them from the backup drive into the music folder of the NAS. My HDX is able to access them as far as I can tell.
Posted on: 11 September 2010 by aht
How do you do that? I don't have the latest HDX software (long story). I have deleted numerous albums with DTC; now System Status says
Recycle Bin - 61 albums
Recycle Bin - 0 MB
Huh? Are they completely deleted or not?
Posted on: 11 September 2010 by David Dever
No - and you should definitely update (or send to us to do this for you).
