What CD Player
Posted by: bigtrak on 27 November 2001
I'm just getting in to this naim lark. Just wondered if I could pick your brains. I am after a CD Player but as yet can't afford any of the Naim ones. Does anyone have any suggestions for alternatives - I do not mind going second hand and often feel you get better value for money especially as I can't really affoed more than £350 - £400.
People seem to say good things about the following CD Players but I would be interested in your veiws when they are partnered with naim kit ( by the way I have a NAC62 & NAP140 new style)
Rega Planet
Quad 66 or 67
Micromega (which model)
Arcam CD72
Manrantz cd cd6000ose
Any Linn ones?
Any others
Thanks alot sorry if you have coverred this topic before.
-=> Mike Hanson <=-
Not sure how it sounds through Naim, but I shouldn't think the NAC62/140 would bugger it up too badly.
John Schmidt
"90% of everything is crud" - Theodore Sturgeon
Unfortunately the build quality is terrible: The first one failed after 20 minutes, the second failed to work at all and the (current) third one developed the same fault as the other two (won't read the TOC) after just over a years worth of use. If I leave it switched on all the time it is OK though.
Oh and the controls are really tacky. It replaced a Marantz CD50SE which did sterling service making the LP12 seem even more wonderful...
If you can find a used CD3 in your budget I would go for that--by far the best player available for the money, and can still, I believe, be serviced by Naim.
There is a rather grand leap in performance when going from a Rega/Rotel/CAmbridge/Arcam/etc to a CD3.
Cheers and good luck!
Bob
I've used Arcam players and they're ok. In my bedroom system I use a Micromega Leader II and Meridian 203DAC which cost me something like 300 quid for the pair used. Very good sound for the money - smoother but not as detailed as my CD3.5 though.
Steve
Graeme
Apologies for my poor ability to express what I meant clearly. I will do better.
In saying "Save your hard earned until...", I was trying to say "Save MORE hard earned until you can afford a Naim cd", and not "Keep your hard earned and find a Naim cd within your existing budget".
Graeme
Originally posted by Jez Quigley:
There are some 3.5's & CDI on loot now for around £650-£700
I paid £650 for my mint CD3.5 from an online dealer so it's worth checking around them as well. I don't think I've seem one significantly cheaper than that anywhere. There have been a few CD3's on loot for around the £400 mark though.
I heard a CD3 when I bought my original Naim system and it sounded very good with 92R/90 & Credos. I'd say it was perhaps a little more forward and perhaps rawer sounding than the CD3.5 (although I've never done a side by side comparison and it could just be that my system now is better bedded in that the demo system was) but still very entertaining.
Steve
Used 3.5 @ £300-400, hmmm where? Agreed CD3's are out there at 400 but CD3.5, nah
I paid £450 for my mint CD 3.5 off LOOT. OK I was lucky - but I was patient too.
Stephen
The dealer may still have it.
Speak to Andrew at Image Audio in Leeds 01132789374.
Good Luck
SteveD
The 3.5 is excellent though - well worth saving up for - now, does anybody know where I cn pick up a second-user FlatCap at reasonable cost - doesn't seem to be many around??
David S
Someone correct me if I'm wrong.
Phil
Arcam CD players are a reasonable match for Naim, My mother uses an Arcam 6 through a Nait 3 and Kef speakers, it sounds fine
p.s. If you do find a CD3, pay £50 also for a new NAIM interconnect for the CD3. Naim's current CD interconnect is better than the one supplied with Naim CD3's.
