250 with mixing desk
Posted by: Not For Me on 05 April 2001
Any suggestions on how to wire from 2 x TRS to the male XLR input on the 250 ?
I have heard various views about co-ax cable, twisted pair. mains cable etc.
Any ideas ?
I would like to use a 250 fed from a Behringer mixing desk with balanced outputs on TRS jacks.Any suggestions on how to wire from 2 x TRS to the male XLR input on the 250 ?
Naim stuff just ain't this normal I'm afraid. The power amplifiers are built with very little protection, and it is the preamps that set the safe operational conditions for use, effectively they must act as some kind of band pass filter. As a holistic approach this works great, but in isolation it ain't too clever.
So, your options are:
1) ignore this advice, and risk it - there are more than a few people out there using non-Naim preamps with Naim power amps, one hi-fi reviewer springs to mind. Problem is that it may take your speakers out if it becomes unstable.
2) Buy a Naim preamp, which will also require a Naim power amp. Problems are cost, and more stuff in the signal path than if you used an alternate.
3) Ditch it - The 250 is a really great hi-fi amp when used within its design parameters, it is simply not a pro amp. Possibly more cost effective to buy a good pro power amp, Bryston springs to mind as being a powerful, robust, and quite musical alternate. The 250 has a good resale value
I have done a lot of monitoring through my Naim kit, and I love using it for this purpose, but I already owned a full Naim amp combo, so buying a additional (and expensive) preamp when I did not need any of the functionality was not an issue. Your mileage may vary.
Tony.
I think you'll be pleased with the results. We didn't use the NS10's much until we put the 72 180 in there.
Mickey Dale
Stephen Bennett. Composer and sound design. (UK)
http://chaosstudios.gen-next.com
henry fool http://www.collective.co.uk/henryfool The Fire Thieves: http://tft.gen-next.com
Author of 'The Fast Guide To Logic' http://www.pc-pubs.demon.co.uk/fgel.htm
and 'Making Music with E-Magic Logic Audio http://www.pc-pubs.demon.co.uk/mmela.htm'
That's not to say that in most domestic setups it wouldn't sound better with a Naim preamp.
