Where's your balance
Posted by: Matthew T on 27 February 2001
does anybody actually routinuely use there balance control and is it really necessary?
Matthew
Never use it otherwise!
Andy.
Andrew L. Weekes
alweekes@audiophile.com
The secondary use is to isolate the various sonic elements when listening to the Beatles. ![]()
-=> Mike Hanson <=-
Also, for many years, I got lower volume from the left speaker for some reason, so I sometimes compensated for that - but not always, since the balance changed with volume, and it was a PITA to keep the sound centered. BTW, the problem appeared to be in two successive tonearms.
BAM
If I centre the balance, the bass booms from the right side; there just seems to be more "stuff" happening on that side.
I set the balance at 11 o'clock to compensate. I pretty sure it's not psychoacousitc.
Mike
I don't know why it is designed in as it adds extra circuitry to the signal path.
BAM
With the exception of the 5 series!
Andy
Andrew L. Weekes
