Upgrading
Posted by: Gunnar Jansson on 15 August 2001
I would like to have some opinions about upgrading my current sytem. This is what i got: Naim CD3, nac 92, nap 180, Epos ES 11 on stands. All naim cables and interconnects. I would like to keep my 92 as I sometimes play some Lp´s om my Rega planar.
The dealer says go for a CDX but that´s too much money, at least for me. Someone else said change the speakers, but I really like them and I believe that they can perform even better.
What about an external PSU? A Hi Cap or a flatcap.Is that the way to go?
I could stretch to about 1000 £ on this upgrade.
Greetings
Or mabye a second hand cd3.5 to be honest I havn't heard this one in action but its said to be better, (Although to be honest I like the idea of the central pivoted lens on the 3, it smacks of better isolation than the lens in the 3.5, but hey as i said havn't heard it.)
I'd say, go for the 3.5
Then later, when funds allow, you could ad a flatcap-II to power both your 3.5 AND your 92.
This is a more affordable and IMHO worthy
improvement.
Good luck
Greetings from Holland,
Alco
Figure out what you want to improve. What bugs you about your system? If you really like it, why change?
If you just want to buy yourself a gift, try a hicap for an immense improvement and as prep for a potential preamp or amp upgrade.
Regards.
Phil
For some very odd reason I want to get more detail in the system. Am I nuts? Should I look for a used 180 now? And do the little tweaks like Nordost points or Final ball bearing insulators work? Also, my rack has the CD on top shelf with Tuner on top, is this a no no?
Upgrading to a CD3.5 or 5 is probably a *sidegrade* used "naked," but at least with these you can add the 'cap, which would definitely be a worthwhile upgrade, and it's still cheaper than a CDX.
It's a pity you don't live in the UK, as I'll be selling my CD5/FC2 combo towards the end of the year to upgrade to a CDX, and I'll want about 1200 GBP for them (they cost 1600 new.)
It's always a nice day for it, have a good one ![]()
Steve
The 180 is great enough for the Es11's
CD3 ->3.5 is a sidestep "at best" ( nice one Eric)
Your not even hearing what you CD3 can do properly yet. The preamp is a massive bottleneck at the moment. I wouldn't mess around with *capping the 92..go for a better pre amp, the best you can get, either new or seconds...Go for 102 or s/s other pre!
It's all about building blocks ( like lego! Bloody expensive Lego though!)
You know it makes sense Rodney :->
Goose
Thank you all for your opinions. It looks to me like a pre-amp upgrade is the way to go.
A friend of mine has the cd 3,5 and I couldn´t hear any major sonic differences between them in my system when we tried it at my home. My thoghts when buying the 180 was that it would drive the ES11 well and hoping to get hold of a 82 in the future,which would be a good partner. (hopefully second hand)
Liked that one Goose, Yes i agree,it`s quite an expensive LEGO.
By the way has anyone tried soft compliance feet under the Cd-player and Speakers ? I recommend that. In Sweden you can buy something that would be translated as SD-feet. Its rubberfoam which comes in different types depending on the weight of the object you are using. It is a very cost-effective upgrade. A set for the speakers cost about £15.
see you at the Forum!
