Plasma air freight OK ?
Posted by: SC on 19 January 2009
I was about to have a Kuro plasma screen air freighted out to me from the UK, but I've just had someone warn of potential issues with Plasmas being affected by the incurred air pressure....?
Anyone have any knowledge of this ? What do you think ?
Thanks, Steve
Posted on: 19 January 2009 by jon h
The air pressure inside a plane is usually about the equivalent of 14000 feet above sea level. this shouldnt be a problem, i would have thought?
Posted on: 19 January 2009 by SC
Hmmm, I tend to agree....I hadn't given it any thought as I just didn't consider it an issue...I'll try and get an answer from Pioneer UK...
Posted on: 19 January 2009 by Don Atkinson
More like 8,000 ft. But i have no idea how 8,000ft would affect a plasma - anybody on here from Lima, ar even Aspen who has a plasma? there are plenty in Calgary at 4,000ft
Pressure at sea level is about 1000 mb and at 8,000ft its about 750mb. Strikes me the bigger risk would be down to "baggage-handling"
Don
Posted on: 19 January 2009 by Bananahead
But why buy the plasma in the UK?
I would worry about warranty.
Is it not available locally?
Available, but over twice the cost - was looking at over £4k for a 50", which was slightly ridiculous....Plus, the ltd edition white version of the Kuro was only released in Europe...Singapore was my best bet, which of course I checked out, but no....
Don - thanks for your more constructive input. I'm surprised that the hold of a plane is actually such a relatively low pressure, amazing. I'm not worried about the handling, it will all be crated up etc, it's more the Thais at the receiving end I'm concerned about ! Big Grin
Posted on: 20 January 2009 by Derek Wright
I have seen a picture of a plasma screen that been placed horizontally and the glass had broken. So you have to ensure that the screen is kept vertical.
Posted on: 20 January 2009 by Exiled Highlander
SC
the passenger cabin is pressurized this way as well...that explains the sore ears when you descend and the pressure adjusts....
Jim
Posted on: 20 January 2009 by SC
Thanks Derek. Fragile little things hey ! It's all in it's original packaging, then into a crate, so should all be ok, unless they stack a fridge or a car on top of it or something... Roll Eyes
