Which input for a DAC
Posted by: gand on 25 April 2009
Hi
I think I have search this forum but couldn't find an answer.
I have bought the Lavry DA10 DAC, so the question is, which input on my 282 should I use for this purpose. I have a XLR to DIN cable, unbalanced.
Rgds
Ger
Posted on: 25 April 2009 by SC
I presume CD as this tends to be the optimum input, unless you already have this in use...?
Steve
Posted on: 26 April 2009 by goldfinch
I use Aux1 with my Lavry and it sounds so good I have never feel the need to compare it with the rest of my 282 inputs. I also have a CDP, a tuner and the av input connected to a home cinema so in my case I have only Aux 1 and 2 available. Why should CD input be the optimum?
Posted on: 26 April 2009 by SC
Originally posted by goldfinch:
..Why should CD input be the optimum?
Surprises me too, but on a 252 at least apparently so ...
Steve
Posted on: 26 April 2009 by u5227470736789439
Too much is made of this.
On a high quality pre-amp the best thing to do is connect it up and simply listen to some music.
The whole input difference thing has gone so anal that I am sure the idea has not seen sunlight for months!
ATB from George
Posted on: 27 April 2009 by james n
Big Grin - quite right George.
Posted on: 27 April 2009 by Former member
I use the CD socket on my 282 for the Lavry-DA10.
Sounds fantastic.
Stu
Posted on: 27 April 2009 by pcstockton
Nor the people who like to ponder the question. Winker
