SNAPS2 with CD3.5
Posted by: Steve G on 09 August 2002
As my Naim amps aren't in use these days I suppose I should try the SNAPS2 powering my CD3.5. Has anyone tried this and does it make a worthwhile difference?
Steve
Posted on: 09 August 2002 by Mike Hanson
Yes. A SNAPS2 (dual-railed) is about the same as a Flat-Cap on a 3.5. It provides a very worthwhile improvement.
-=> Mike Hanson <=-
Posted on: 09 August 2002 by Steve G
Cheers for that. The SNAPS2 is already dual railed so I'll probably give it a go tonight.
Steve
Posted on: 10 August 2002 by Edo Engel
Steve,
Why don't you consider selling it to an exceptionally friendly Dutch guy?
Edo
Posted on: 10 August 2002 by Steve G
Originally posted by Edo Engel:
"Cheers for that. The SNAPS2 is already dual railed so I'll probably give it a go tonight."
Steve,
Sorry mate, but I still have plans for my unused Naim kit (32.5/SNAPS2/IXO/140/Credos) as it'll probably form the basis of the system in my new room when it's built.
Steve
Posted on: 14 August 2002 by Mats
How do I now it is a snaps2, mine is from 1987.
Mats
Sagitarius in aeternum
Posted on: 14 August 2002 by Steve G
The later SNAPS (probably including your one) have 2 4-pin inputs. The SNAPS2 modification consists of converting those 2 4-pin DIN's to a single 5-pin therefore becoming a dual rail power supply for the pre-amp.
It's a very simple mod and if you do a search for "dual railing a SNAPS" you should find instructions elsewhere on the forum.
Steve
