555PS & HDX
Posted by: docmark on 11 August 2009
Hello - What part of the HDX does the 555 power? If I use another DAC, ie digital out to the other DAC (Meitner), is it then a waste of the 555? Or, I suppose, is it just better to wait for the Naim DAC?
Posted on: 11 August 2009 by js
Power supply has no effect in dig out but don't be surprised if you don't prefer the inyernal with PS to an outboard. The supply makes a significant difference and can later be used for the DAC.
Posted on: 11 August 2009 by pcstockton
Agreed. The HDX with 555ps using its internal DAC was so good, even through a lowly 102/200, I cant imagine a source getting better than that.
I would say, get the 555ps first. Then demo some DACs to see if you can improve it even further, given standard reference to VFM.
-p
