CDX2 and cabling
Posted by: kuma on 11 November 2003
Has anyone tried something other than Chord or Naim cables?
Posted on: 12 November 2003 by kuma
Originally posted by Idoru:
I would suggest you audition the LAT IC-200 - available from Audusa (http://www.audusa.com) on a 30-day trial - DIN > DIN costs just under £100 - offers quite remarkable soundstaging, imaging, detail and refinement - testimonials scattered around the Net suggest it can more than hold its own against more exotic cables (Nordost etc) five or six times the price - a matter of taste, obviously, whether it is 'better' than Chord or Naim, proof of the pudding is in the eating etc. It has also been mentioned on this forum before, so worth doing a search here too.
thanks Idoru.
A lack of reposnces suggest that everyone is probably using the Naim or Chord cables it seems.
Posted on: 12 November 2003 by Emil
If you have $500 burning a hole in your pocket you might want to check this out as an alternative to the Nordost.
Stage 3 Concepts
Emil,
Thanks for the lead. I take it they are close to Nordost's voicing then?
In an all-Naim setup, the standard Naim cables, and in some instances Chord alternatives, are generally viewed to be by far the best option. With other brand components in the mix, there are benefits in trying alternatives. I would strongly recommend you try the LAT for the 30-day trial period - you can always return it if it sucks in your setup.
so, LAT stuff does better in stage/imaging department than Naim/Chord?
To be honest, I don't need any more *refinment and staging' stuff.
Posted on: 12 November 2003 by Dawie
If you're planning to add an XPS2 somewhere down the line, then this cable will become obselete as you'll be using a Burndy then.
Don't I still need a pair of IC from CDP to preamp?
Burndy is a connection between the power supply and CD unit, no?
Posted on: 12 November 2003 by andy c
I currently use Kimber KCAG...and I'm happy with it.
Won't look at cables again until harware updates which will be happening soon... Smile
Also, why are you thinking of not using the Naim supplied lead?
Kuma
Sorry if I gave the impression that I was familiar with the cable. I only wanted you to become aware of an alternative.
Emil
Naim supplied lead? This unit did not come with one. Altho, it came with a power cord.
I haven't tried any Naim or Chord cabling yet.
Posted on: 12 November 2003 by Naimed
kuma,
Give your dealer a buzz right away.
Cables that I have tried (terminated to DIN-DIN) are various Mogamis, Canare, Klotz and Cat5e. The Andrew Heliax was RCAs terminated and I use a Mayware adaptor for this purpose.
I'm currently using Naim's.
Posted on: 12 November 2003 by Steve Toy
You only have to look here
Steve.
Originally posted by Naimed:
kuma,
Cat5e with CDX2? Big Grin
How did they do?
How did they do?
Not nice... Frown
The Mogami 2534 mic cable is about £1/m. Mogami 2803 (not available outside Japan except Germany under another name) is about £14/m. The 2534 were the closest to Naim's IC without killing too much of the music. I wont attempt to lure you with hifi mumbo jumbos of the more expensive boutique cables out there. Big Grin
A buddy is using the 2534 from a Meridian 506.24 to 82, which he prefers over Naim and Chord Cobra. The 2534 was terminated to a pair of Neutrik Profis and the 2803 to a pair of bullet plugs.
These cables are left-overs from my toob days. However, I'm relunctant to spend more time on DIY and tweaks now. Get 1 that work...and enjoy the music instead.
Posted on: 13 November 2003 by kuma
I see what you mean. Normaly, I just use the same one I've been using for last 5 years. but these cables are so stiff, they will not work with Naim and preamp on the same rack. Also, this producer does not offer DIN connection either. I am suing one of their entry level ICs for now and from what i hear, I think they are not a good match. ( altho, these are the only single-ended cable i have in the housel, atm )
So, I am forced to look for something that work physicaly and sonically. I know Naim and Chord are the de facto cabling.
And i have experienced a little bit of the good effect when I used an aftermarket main on Headline. I preferred the Naim supplied power cord. But, I have no way to evaluate how good Crysalis IC is since they are hardwired to the unit.
Thanks for your reply. I am sure this belongs in 'every Naim Newbie's book'.
Someone ought to write a book 'Naim for Dummies'. Wink
Posted on: 13 November 2003 by Tennispro
Paging Stephen Toy.
Did you go ahead and purchase the I/C's that you raved about? Can you tell me more about the company and how much they are in American money?
Tennispro
