Get your alignment right or dont bother with LP's
Posted by: jonni on 11 March 2003
I've listened to so many bad turntables in my life that it is apparent that most people dont set them up right.These same people then moan about the sound of their turntable and blame all their problems on it or and look for the next up-grade.
Simple fact is a correctly aligned cartridge is a bigger upgrade than anything I can think of.
Get your self a decent protractor and a good magnifing glass,but first measure the pivot to spindle distance of you arm and make sure it is in the right place , within 1mm or less.If your arm is not set in exactly the correct place all alignment is a waste of time , it will always be out.If need be get a new arm board and re drill it acurately.
Many people have the VTA too low because the cartridge is mistracking and causing harsh treble, with correct alignment you will first get a cleaner fuller sound with much reduced distortion and deeper bass , you will then find you can raise VTA and bring in a crisper treble with no harshness or distortion.
Dont think about upgrading cartridges . powersupplies or arms until you have this sussed.
Jonni's rant is now overfor today.
