Is the NAC92 better than the NAC72
Posted by: mystik on 15 January 2003
Please can someone tell me the difference between the 2 other than the box size.
Thanks alot.
Posted on: 15 January 2003 by David Stewart
There's quite a lot of info on here
(Naim Audio Short Guide) which you may find helpful.
Many people seem to rate the 72 highly. It's probably a step up from the 92 (which was based on the Nait3 integrated amp), but not if you value remote control. Others may disagree of course - they usually do.
"Opinions are like belly-buttons, everybody's got one" Posted on: 15 January 2003 by Noel
The 92 replaced the 62. The 72 was the model above both of them. IMHO the 72 sounds a lot better and I own one. Its only half width and cannot have a remote control, this may be important to you.
Posted on: 15 January 2003 by Frank Abela
Easy one this. The 72 is better than the 92, by quite a margin.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 15 January 2003 by mystik
Thanks alot everyone. I really appreciate your comments.
