Wide Bandwidth System
Posted by: DAVOhorn on 15 February 2003
dear All,
My system is able to currently realise 35hz-100khz. Not bad but a bit lacking in the bass.
A friend and i have been playing with our own designs of Sub woofers.
So today i added a sub to my system and can now cover from 10hz upwards.
The sub uses a 21" bass unit and a 500w power amp module and crossover.
I really did not expect such a transformation to the system. I will probably have to rebuild the house within 6 months. But interestingly at normal listening levels if you listen to the sub only the output is not overpowering .The x over frquency is 60 hz so at the 35 hz roll off of the horns the sub is coming into its own and therefor does not adversely affect the sound from the horns.
A satisfactory days work.
regards David
regards David
